Old 04-20-2017, 04:27 PM   #1
aftermarket ball joint for lower applications
Has anyone been able to fine ball joints that are extended over oem so improve the roll center in lowered Yaris'?
My ball joints will need to be done down the road and I figured since I'm lowered an experience some bump steer, I'd try and source some ball joints that help correct the control arm angle. Problem is I haven't been able to find any online.
Has anyone found or used an extended ball joint on their Yaris and is there any other options for us lowered yaris guys?
Old 04-20-2017, 09:04 PM   #2
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Thats on my to do list along with sperical bushings to replace the whiteline crap
Probably going to use screw in mopar style and ream the spindle to accept.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 04-20-2017, 09:34 PM   #3
What wrong with your whiteline bushings?
Old 04-20-2017, 09:44 PM   #4
malibuguy
Obsessed with 1.5L
They suck haha
-96 Tercel 4dr
Old 04-20-2017, 09:51 PM   #5
Jason@SportsCar
I don't think anything new has come along:
http://www.yarisworld.com/forums/sho...ht=ball+joints
If the bump steer is what you are worried about opt for the steering links, because moving the ball joint just lowers the control arm, it does not correct the steering angle.
Old 04-20-2017, 09:54 PM   #6
Did you ever run the one from the japan?
If I could get the dimensions of the oem one I'm sure there are others that would fit into a Yaris control arm that are longer and correct the roll center.
Jason, are you just using the oem ball joints?
Old 04-20-2017, 09:57 PM   #7
Jason@SportsCar
I have not changed any of the joints or bushings, all OE. *Except the upper strut mount, replaced those marshmallow with the Cusco units.
Old 04-20-2017, 10:03 PM   #8
Good to know, thanks
Old 04-20-2017, 11:56 PM   #9
enviri
enviri's Avatar
Drives: 2010 Yaris
there was a company in japan called MOONFACE that made ball joint and control arm assembly for our lowered cars..
edit: here's the webpage. no more control arm.
http://www.superlap.jp/item_detail/2/
they also do tie rod ends.
Old 12-17-2019, 12:48 PM   #10
ElMagnifico
Drives: 2012 Sedan
have you gotten to try them?
ElMagnifico is offline   Reply With Quote
Old 12-24-2019, 10:07 PM   #11
malibuguy
Obsessed with 1.5L
I should of been more specific...the rears separated within the first year of use. So i get an occasional clunk (or slap) under very hard braking. They really do not seem to move about or go anywhere, however I feel there is improvements to be had
-96 Tercel 4dr
Old 12-25-2019, 12:07 PM   #12
ElMagnifico
Drives: 2012 Sedan
wow, i was/am getting a similar noise. i knew it had to be because of the bushings but i didnt know specifically what. i dont think i will be changing them though. Based on what you stated, which ones do you feel would have been ideal?
Old 12-26-2019, 11:17 AM   #13
No I haven't had any luck finding them
Old 12-28-2019, 04:05 PM   #14
malibuguy
Obsessed with 1.5L
I haven't really looked around. By the design the rears are goofy AF...and even harder to figure out a better solution. Id be interested to see if SuperPro has a better design then WhiteLine. The front bushings are pretty normal and straightforward tho I have no problems with them.
-96 Tercel 4dr
URGENT. BALL JOINT REINSTALLATION QUESTION xb visitor DIY / Maintenance / Service 4 05-09-2014 06:02 AM
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 07:38 PM
Front Lower Ball Joint Cotter Pin Replacment GrayYaris DIY / Maintenance / Service 5 04-25-2014 04:30 PM
Putting on dust cover boot ring on ball joint yaris4062007 DIY / Maintenance / Service 10 04-21-2013 12:51 PM
Ball Joint on Bottom Arm David Godfrey DIY / Maintenance / Service 1 04-18-2010 06:27 PM
