Deng, do you have a rear sway bar on your set up?
I'll be getting a corner balance at a local well known shop once everything is all set up. I'll have to ask FA about the rear spring rates but as far as I last rear they were fully custom.
#2 | |
Radical Dreamer
Drives: off of T9 Join Date: Jun 2017
![]() I pulled my rear bar off when I installed the coilovers, I didn't see a need for it with the stiffer rear springs.
If you lack driver skill, add horsepower. |
#3 | |
#4 | |||
Radical Dreamer
![]() I was going to take my rear shocks to Feal, but they said they do not do revalves on Cusco. Plus with the Bilsteins, I can just drop them off and not have to worry about any downtime with the car. Which brings up another question I have about springs...I'll make a seperate thread about it. Quote:
#5 | |
Hard to go wrong with Bilstein, lots of options and great tuners out there. Guy Ankeny at FR-Sport can do wonders with those, as can Bret Norgaard at Yawsport (he is an ex Bilstein engineer).
| broken coil spring | jmranger | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 06-29-2021 04:56 AM |
| Front coil spring orientation? | Pinchlite | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 03-05-2017 02:17 AM |
| About spring rates... | SaerinRhoe | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 11-13-2009 05:08 PM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
| ideal spring rates for coil-overs on Yaris | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 30 | 01-27-2009 04:24 PM |
