Old 03-22-2017, 05:50 PM   #1
jmranger
Drives: Yaris 4-dr 2011 MT
broken coil spring
Hello,
Looking for another opinion...
2011 Yaris sedan, bought new. No other driver. Used in an area where potholes and winter abrasives is the normal way of life.
Front passenger coil spring broke at ~3 years, 42000km (26000mi), around 1/2 turn from the top end. Replaced under warranty.
Front driver coil spring just broke, at ~6 years, 61000km (38000mi), at the same 1/2 turn from the top end. Out of warranty this time.
No damaged wheel/tire, ever.
Part of my brain is shouting "manufacturing defect", but I don't really have arguments to challenge the local Toyota shop that claims potholes, rust and bad luck.
Thoughts?
Thanks.
jmranger is offline   Reply With Quote
Old 03-22-2017, 06:35 PM   #2
You likely won't have any luck since its out of warranty, and like you said in the salt belt. It does sound like a defect as the springs are not a common fail part in the yaris.
Not sure where you're located but I have all 4 of my oem springs sitting in my shed and they're currently on sale in the classifieds. No rust or cracks in them
Old 03-22-2017, 06:51 PM   #3
jmranger
Thanks for the offer. I've already approved the repair, just not picked-up the car yet.
Both have now failed, so that should be the end of that story.
Old 03-22-2017, 09:33 PM   #4
I don't think I've ever heard of a spring breaking on a Yaris/Echo/Vitz.
Old 03-22-2017, 10:20 PM   #5
jmranger
Well, now you have...
(Thanks for the info)
Old 03-22-2017, 10:53 PM   #6
Adriaan
In between cities
Adriaan's Avatar
Drives: 2006 yaris ce
My front Eibach broke at 330000km and the rear at 380000km. I had forgot they had a lifetime warranty at the time when it when to the scrap metal recycling bin.
Adriaan is offline   Reply With Quote
Old 04-24-2017, 10:20 AM   #7
johnny_vitz
Drives: 2005 Toyota Echo
I just did a set of rear Springs on a 2009 Yaris hatchback at work, the RR had a 3 inch piece broken off at the bottom and you could see a crack in the spring itself (rusty at the point of break) The good news is it took Toyota a few days to get them to us, so it's definitely not a common failure.
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Front coil spring orientation? Pinchlite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 03-05-2017 02:17 AM
Broken spring in 4 year old Yaris? PEneoark DIY / Maintenance / Service 7 03-05-2013 01:25 PM
Spring low vs coil low XyresicPsych Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 05-25-2012 02:57 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
