Old 11-09-2017, 02:35 PM   #1
tmontague
tmontague's Avatar
Originally Posted by Jason@SportsCar View Post
You guys are in the range in the front, but far to soft in the rear. Need to get it up around 9k in the rear with that rate front.
As in a higher rear spring rate than front?
I don't know if I could handle that amount of over steer that I would expect from that set up. Would you then recommend removing the rear sway bar with a high rate in the rear?
Old 11-09-2017, 02:51 PM   #2
Jason@SportsCar
The stiffer rear spring help the car put power down on corner exit. No need for a rear bar when the shocks and springs are right.
broken coil spring jmranger Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-29-2021 04:56 AM
Front coil spring orientation? Pinchlite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 03-05-2017 02:17 AM
About spring rates... SaerinRhoe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 11-13-2009 05:08 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
ideal spring rates for coil-overs on Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 30 01-27-2009 04:24 PM
