Old 11-09-2017, 02:51 PM   #1
Jason@SportsCar
Originally Posted by tmontague View Post
As in a higher rear spring rate than front?
I don't know if I could handle that amount of over steer that I would expect from that set up. Would you then recommend removing the rear sway bar with a high rate in the rear?
The stiffer rear spring help the car put power down on corner exit. No need for a rear bar when the shocks and springs are right.
broken coil spring jmranger Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-29-2021 04:56 AM
Front coil spring orientation? Pinchlite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 03-05-2017 02:17 AM
About spring rates... SaerinRhoe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 11-13-2009 05:08 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
ideal spring rates for coil-overs on Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 30 01-27-2009 04:24 PM
