#181 |
Subtle little changes that go a long way. Love it.
For the foot lights, should have gone full 90's and made it a neon blue, or black light lol. |
#182 |
#183 |
![]() ![]() ![]() Drives: yaris 2009 Join Date: Nov 2014
How did you wire these leds ??
Do they open when u open the door? Sent from my iPhone using Tapatalk |
#184 |
#185 | |
Damn sounds easy. I will add it to my todo list for the month ;) If you have a picture of the wires that I have to use please post them :) Sent from my iPhone using Tapatalk |
#186 | |
Check out CTScott's post 14 here: http://www.yarisworld.com/forums/showthread.php?t=12220 You'll see the pink and blue wires. |
#187 | |
Thank you. I find the picture. One more thing. Where you bought the led stripe? eBay? And if yes do you have a link for it ? Sent from my iPhone using Tapatalk |
#188 | |
https://www.ebay.com/itm/10X-Festoon...item33b1d04a1c Unless the seller changed the board, those should be the exact ones. I'm using those in the Yaris dome light, trunk light, and footwell lighting; as well as the dome and trunk light of my FR-S/GT86, and the trunk light of my brother's Prius c/Aqua. |
#189 |
48SMD! Crazy I need to put one of those boards in the trunk. Right now, I'm using one that fits in the stock socket which has only about 12SMD.
Sent from my SM-G930W8 using Tapatalk |
#190 | |
Finding Dory
And what about their life circle?? Do they burn easily?? I am looking right now for leds because I want to change all the stock yellow bulbs to white leds and so far I have read lots of bad reviews about the majority of them. I even saw reviews about melted boards What’s your experience? Also I have an interesting question. If I replace the dome light with led bulb, the effect that the light closes slowly works? I don’t know how to describe, but when the light goes off, it goes slowly like it fades with the normal bulbs. I know it’s not that important but I do like it. ![]() Sent from my iPhone using Tapatalk |
#191 |
#192 | |
However, for very important or hard to get to lights, I go to my favorite brand of LEDs, VLEDs. They're very reliable (still have strips from them that are 10 years old by now) and have awesome customer service in case you need warranty work (used once only). Those boards will still do the gradient/fade effect. However, it'll be more in "steps" (I think that's the nature of LEDs). |
#193 | |
Finding Dory
Mmm vleds are out of the question for me because I don’t live in USA and the shippings are more expensive than the cost of the led itself so it’s not worth it Also, as you wired them in the dome light harness, do footwell lights have the fade effect too? Sent from my iPhone using Tapatalk Last edited by miiser; 01-09-2018 at 07:40 AM. |
#194 |
Are these ok for the hvac bulbs ?
#195 |
Those T4 LEDs should be fine. I did have to scrape off some of the plastic in the hole of the HVAC unit to make the hole bigger. If you have trouble fitting those in, you might have to do the same. Although I don't suspect that since the LED boards don't look like it's bigger than the top of the base.
That sucks about shipping costing more than the LEDs from VLEDs. You'll have to find a reputable LED manufacturer/brand in your country if there is one. The footwell LEDs will fade on and off as well. |
#196 | |
Finding Dory
Yes I guess if I want some led bulbs for important lights such as brakes I will buy either Phillips or osram. Thanks for your help buddy I already ordered these leds you mention that you use. I will try to do the same with the footwells as you. Also I purchased some cheap 194 led bulbs too that they claim they are Samsung leds. I will use them on the license plate. And if they are good enough I might use them for the back lights too ![]() Hope it works out ![]() Sent from my iPhone using Tapatalk Last edited by miiser; 01-10-2018 at 01:13 PM. |
#197 | |
![]() They're nice and bright, and are well focused; unlike the cheap eBay ones that died on me after a month or two (a different, cheap eBay one I got for my brother's Prius c is still working just fine tho). Here are my reverse lights from an RS taillight replica. ![]() https://www.ebay.com/itm/2X-7440-130...item36063fb938 Those are the bulbs and seller I got them from. I think the RS taillights' optics aren't very good as I got more light out of the regular Yaris taillights.
#198 |
I'm using very cheap 194's in the license plate, they haven't died on my yet. Been 3+ years now.
Reverse, I got them from a seller locally. Look like normal generic stuff found on eBay, and they are nice and bright. Almost as bright as my friend using HID lol. I have yet to replace any LED I installed, though I haven't found any good 7442 bulbs for the brake light at an affordable price, so halogens are still in there including the flashers. Sent from my SM-G930W8 using Tapatalk |
| Finding Remote/Iginition Wire 2016 Hybrid | drdyzio | Third Gen Yaris General Discussion | 1 | 11-14-2016 06:34 AM |
| Help finding part number | joell | DIY / Maintenance / Service | 19 | 01-06-2015 03:41 PM |
| Need help finding the Japanese part number for the TRD Sway Bar (PTR11-52071) | chalked | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 01-26-2013 03:29 PM |
| need a hand finding these spacers | mr_miles | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 12-11-2011 09:18 PM |
| I need help finding 17's for my ride | Stoln | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 07-18-2009 08:21 AM |
