Super Newbie
Drives: 2007 Yaris Liftback White Join Date: Jul 2007
Replaced worn strut bearings
Finally replaced the strut bearings after about 150k miles (worn strut bearings in attached pictures). When taking them out, they were completely worn and had tons of play. These top strut bearings hold most of the load and deal with up and down and side to side forces, so they definitely will wear out quicker if you are lowered and do lots of spirited driving.
If these are worn, they will effect the way the car handles. My steering wheel was crooked even when getting multiple alignments and the steering felt slopping and all over the place. When replacing the strut bearings, steering feels a lot more direct, I turn the wheel and it goes in that direction. Steering wheel is straight now instead of crooked so it fixed that alignment issue. Would definitely recommend replacing these if you haven't yet. Toyota Part# 48619-0D011 Last edited by FunctionSpec; 02-20-2018 at 03:14 AM. Reason: Part number |
Being relatively new to these cars, is it an involved job? I'm assuming spring compressors are required and an alignment afterwards? Not even sure, do these cars us a concentric bolt for alignment? This would make a great DIY guide. Not sure if there is one on the site already.
Thanks for posting!
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 02-28-2018 at 08:28 PM. |
#3 | |
Super Newbie
#4 | |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Replacing just these bearings would have no influence on your steering wheel position, that was likely the guys doing your alignment being lazy and not centering the wheel.
But yes we should look into replacing these if you modify the suspension after 100k, they're only about $15 each |
| Clutch replacement...now worn wheel bearings??? | ejaf | DIY / Maintenance / Service | 2 | 02-02-2017 09:27 AM |
| 1.0 Aygo Engine: clicking noise - worn valves or bearings? | dj92 | General Yaris / Vitz Discussion | 2 | 06-07-2016 03:54 PM |
| DIY: Rear shock, sway bar, and strut brace refit | Tapokata | DIY / Maintenance / Service | 19 | 05-31-2016 01:05 AM |
| Strut Bearings | Golddeenoh | Performance Modifications | 6 | 04-28-2014 07:59 AM |
| Differential bearings worn out - car shaking | Unicron | DIY / Maintenance / Service | 7 | 06-13-2012 01:07 AM |
