Old 03-22-2018, 12:35 PM   #1
tmontague
tmontague's Avatar
based on your mileage and heavy dose of winter salt it can either be a somewhat frustrating day at home or an easy one (but potentially costly one) for a shop.
Once you have it off, if you apply anti seize to it like you should future removal is simple. I wouldn't recommend trying it at home without an air chisel, some sort of penetrating fluid and also go to a local hardware store and grab a long threaded bolt (as long as you can) and some matching nuts and various sized washers. You can make your own press to remove the dust shield from the hub if it is seized on (hint: it probably is). A torch will also help make them easier to separate.
Old 03-22-2018, 12:47 PM   #2
Pinchlite
Drives: 2007 yaris HB
spacer.
Sounds like a job for someone that has more then a gravel driveway.Going down to my mechanic and see what he will charge.He is really quite cheap compared to other shops as hes retired but still does side work and owns his own full shop.He did both my front wheel bearings for $150.00 labour.
P.S I couldint turn the star spacer down any on the drums.Up is easy peasy.The pads are fine changed last summer but the ebrake needs to be pulled up as far is it will go,even then it does not hold car.Why is is that the yaris ebrake gets loose all the time.Last time I checked metal components dont stretch.
rear hub spacers tmontague Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 08-03-2015 10:42 PM
remove rear door's wondows yarismo DIY / Maintenance / Service 1 05-11-2013 01:02 PM
Installing Rear Wheel Bearing Hub brad4ds Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 07-22-2011 06:34 PM
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 12:29 PM
