Old 03-22-2018, 01:35 PM   #2
tmontague
tmontague's Avatar
based on your mileage and heavy dose of winter salt it can either be a somewhat frustrating day at home or an easy one (but potentially costly one) for a shop.
Once you have it off, if you apply anti seize to it like you should future removal is simple. I wouldn't recommend trying it at home without an air chisel, some sort of penetrating fluid and also go to a local hardware store and grab a long threaded bolt (as long as you can) and some matching nuts and various sized washers. You can make your own press to remove the dust shield from the hub if it is seized on (hint: it probably is). A torch will also help make them easier to separate.
rear hub spacers tmontague Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 08-03-2015 11:42 PM
remove rear door's wondows yarismo DIY / Maintenance / Service 1 05-11-2013 02:02 PM
Installing Rear Wheel Bearing Hub brad4ds Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 07-22-2011 07:34 PM
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 01:29 PM
