It's going to be really hard to say without either as much info as possible and/or disassembling the trans from the engine.
If the clutch pressure plate wasn't perfectly centered on install it could cause the symptoms you're experiencing. The engine/trans mounts would be the cheapest and easiest to check so start with that
| Tags |
| clutch, flywheel, noise |
| Strange noise after new exhaust install | phaznet | DIY / Maintenance / Service | 3 | 05-03-2015 02:04 PM |
| metallic noise when accelerating | poida | DIY / Maintenance / Service | 3 | 03-29-2015 12:20 AM |
| Irritating Door Noise | Anakha56 | Third Gen Yaris General Discussion | 1 | 04-21-2013 11:06 PM |
| humming noise | greg86m | DIY / Maintenance / Service | 6 | 04-14-2012 10:15 PM |
| Strange noise coming from left door of car | daibatzu | General Yaris / Vitz Discussion | 3 | 11-19-2010 09:58 AM |
