Old 04-12-2018, 11:20 AM   #1
enviri
enviri's Avatar
Drives: 2010 Yaris
500 hp in a 1nz is def possible if you got that dedication, maybe ~350 is where you could be aiming, which can be achieved semi-reliably with some elbow grease.
i had an 02 spyder, fun car, always wanted to drop a 2gr in it, making it a nice mini evora.
Old 04-12-2018, 12:19 PM   #2
speedworxs
Drives: |Mr2
Post
yeah, i think 350 is achievable. i posted blown_xa build, since he made that power level on stock components. i am upgrading rods, pistons, and cam...
depending on turbo selection i don't think 350-400 is unacheivable.
also, i am using the c56 trans from my mr2, but the 1nz bell housing.
the mr2 only weighs 2200 so even if i get to 250hp, i almost double the factory power, and the 1nz is lighter with the turbo, than a 2zz.
speedworxs is offline   Reply With Quote
Old 04-13-2018, 11:27 PM   #3
speedworxs
Drives: |Mr2
#1, combustion chamber (obviously) just soften some of the edges, and shine it so carbon won't stick
#2 intake port* this port is actually really well done. i admit i'm no expert, but it is clean and straight. no bad bumps or curves. minor cleaning to the casting flashes, the injector bung and the throat/bowl before the valve is all that i think is really necessary on the intake side.
#3 intake from top, again not much to really see.
after i clean the head with some solvent, generally get really high on cleaner solution (and make outrageous horsepower claims), i will take some pics of the exhaust port. which i believe is the exact opposite of the intake... it's too small, has a bump immediately after the valve, and like many toyotas in general, just not a high performance exhaust port (not insulting, meant works fine in factory condition)
Quantum Technology Hydrogen 1NZ Turbo Kit GT1241 JustDidIt Items for Sale by private party 13 08-31-2018 03:07 PM
Turbo Echo - The False Prophet EchoLaQua Forced Induction Forum 12 03-14-2018 12:58 PM
1nz turbo (england) 1nz_tommy Forced Induction Forum 1 10-17-2014 08:06 PM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
