Old 04-28-2018, 08:39 AM   #1
TYaris2010
Drives: 2010 Yaris
My '06 and '08 (both older when purchased) had lock cylinders that would not turn due to contamination. It is not so big a job to take the lock mechanism out and clean it. There is a snap ring that is removed and the guts of the cyinder slides out. The one on my '08 was seized so well that I had to put the body of the cylinder in a vice and wiggle the shaft back and forth little by little until it was freed. I then took the guts out, flushed it a number of times with contact cleaner, until it ran clear. Then I lubricated it well, reassembled it and it's worked fine since. Every once in a while, I spray a bit of electronics cleaner in followed by a lubricant.
Another member posted step-by-step instructions with pics here on the site.
thanks, sounds like a potential plan. I was hoping to just spray something through the entry hole so I didn't have to dissemble it or, worst case, replace w/ a new cylinder with a different key. This car isn't that old, I'm guessing it froze to to not being used.
not sure where the step by step would be located on the site....
TYaris2010 is offline   Reply With Quote
Old 04-28-2018, 10:13 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I'll see if I can find the DIY. I, too, tried just spraying stuff in an attempt to free it up. It did not work. This is a fairly easy job. The hardest part is removing the plastic inner hatch cover, but with a little patience, not too bad. A new lock cylinder will cost you a lot and you have the inconvenience of two keys.
Old 04-28-2018, 02:39 PM   #3
TYaris2010
Drives: 2010 Yaris
Thanks.
I pulled the lock- removing that carpet trim to get to it can be iffy....its supposed to 'look nice' so didnt' want to mar it up.
Two 10mm nuts to remove the lock, pull the little c-clip thing to free it from the trunk safety actuator thing.
Sprayed tons of PB Blaster directly into it....it still will not turn. Dunno whats up. Maybe this DID have a different key and dealer I got it used from (someone traded this in) didn't give them the key.
I see OEM ones for $50-60 but yea then trunk has different key.
It is important to have key access as the release lever by the drivers seat....they can fail, then you have no access to the trunk....
Old 04-28-2018, 10:17 AM   #4
06YarisRS
DISCLAIMER: The DIY below is for a hatchback. I haven't looked at a sedan at all, but I expect it's similar at least in terms of the cylinder.
Try this by member eepp:
http://www.yarisworld.com/forums/showthread.php?t=59514
Old 04-28-2018, 11:07 AM   #5
DISCLAIMER:I haven't looked at a sedan at all, but I expect it's similar at least in terms of the cylinder.
They are different in that the sedan does not have a thumb button.
Old 04-28-2018, 06:08 PM   #6
06YarisRS
Ah, I see. Thanks for clarifying that.
Old 04-28-2018, 10:45 PM   #7
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Usually the valet key will have a gray plastic head, while the normal key is black.
Door lock issue - new key or lock? RedSuns General Yaris / Vitz Discussion 17 11-01-2021 06:30 AM
Original OEM Toyota Yaris SEDAN 5 Piece Floor Mat Set! Including trunk mat! Sale!!! kmcherry21 Items for Sale by private party 3 01-29-2013 03:41 PM
