Old 05-24-2018, 10:51 AM   #1
lespaulstd
Drives: Yaris
I am facing the same issue and will try to replace the clock from a donor cluster. In order to test the "new" cluster, can somebody point me the pinout of the connectors to be able to switch it on and see if the clock works?
It is an European Yaris, and part-number is 83800-0D660
That is the one that I have. I just disassembled mine and hooked it up on my test bench to experiment with it. The clock and odometer are a separate assembly from the rest of the instrument cluster. Does anything at all display on the clock area of yours?
Attachment 50263
Thanks in advance
lespaulstd is offline   Reply With Quote
Old 05-28-2018, 11:40 AM   #2
GTJos
Drives: Yaris 2006 + CorollaVerso 2002
Hi all !
Same problem (for over a year now...)
Happy to find this forum/threat. Are there any real solutions yet ? Thank's in advance !
GTJos is offline   Reply With Quote
Old 08-07-2018, 08:27 AM   #3
lespaulstd
Drives: Yaris
Thanks in advance
Searching this document from this post of CTScott I've been able to check that the donor cluster works.
It is only necessary to connect, pins 1 (12V) and 24 (GND) to power the unit outside of the vehicle. Now my plan is to swap the clock/temperature display of both units.
GI: "YarGauge" replacement clock module (Digital Tach, etc.) CTScott Items for Sale by private party 756 03-21-2013 09:22 PM
05 Echo changing time on clock jambo101 DIY / Maintenance / Service 3 11-12-2011 05:34 AM
Dashboard mount for iPhone 4S? shima In Car Entertainment + Electronics (audio / video / alarm) 3 10-25-2011 10:22 AM
Dashboard remove ... ALL of it Toji Cosmetic Modifications (Exterior/Interior) 7 02-26-2011 07:30 AM
Setting the clock after DST change ToddR DIY / Maintenance / Service 10 03-10-2009 12:33 AM
