Old 06-12-2018, 07:05 PM   #1
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Any lowering spring will alter the ride quality as they're stiffer springs compared to the OEM springs. Also, any lowering springs will reduce the lifespan of the dampers (shocks). So if your car already has some higher mileage to them, you'll have to pull out the suspension twice (once for installing the springs, and another to replace the dampers when they blow).
Any adjustment to the ride height will require an alignment afterwards. Only the front of the Yaris is adjustable. The rear are not unless you use shims.
If all you're looking for is an inch drop and you have higher miles on the car (means most likely the dampers are nearing the end of their life), I would suggest getting some basic coilovers like the Tein Basis Z. They're basic coilovers in that they don't have dampening adjustment, but at least the dampers are valved/paired correctly for the spring rate. And you can dial in just how much lowering you want (within the range it provides, which is a little under an inch min to a little under 2 inches max).
While technically completely true, there are examples in this thread, myself included, of folks that have lowered up to 2" with stock struts/shocks and gotten mileage out of it. I just had my car in at Toyota for regular maintenance. I thought for sure they were going to tell me mine were leaking but they are doing well and I've been lowered for a few years now.
Additionally, I prefer the ride quality after lowering with Tein S. Tech springs than when running stock springs. The Tein's offer a progressive spring rate so it's very nice around town and then sits down under heaving turning. I agree that the Tein Basic's are a good option, but if someone is looking at the budget and has functioning factory shocks/struts, I wouldn't be that concerned about lowering with springs and keeping the OEM shocks/struts for a while.
Just my 2 cents.
On Instagram
On Wheelwell
Old 06-13-2018, 05:08 PM   #2
Just my 2 cents.
I'm riding on S.Tech with OEM dampers with Dory. Doesn't handle as well as the same springs on TRD dampers (what I had on the sedan). I'm experiencing more understeer, and this is with better tires too.
That's why I also mentioned about having higher miles since buying springs and then having to buy dampers may end up costing close to those Tein Basis Z coilovers, especially if labor is being paid twice to remove the suspension. If it's on the lower mileage side, like me with Dory, I'd just throw on springs, granted I already had the springs laying around. lol.
With that said, with a little under 40k miles since putting the springs on, I believe my rear dampers are going out on Dory. Once they do blow, I'll get a set of Tein Flex Z and give the S.Tech's away.
Old 06-13-2018, 06:55 PM   #3
ern-diz
ern-diz's Avatar
Since I don't track my car, I've been thinking about replacing my OEM shocks/struts with Bilstein shocks/struts when they eventually blow. I've been hearing that a good set of springs and shocks/struts can outperform the value level coil overs. Not sure how much truth there is to that, but I've heard it from several sources now.
On Instagram
On Wheelwell
Old 06-14-2018, 01:16 AM   #4
Very much true, but it is best to see if those dampers are valved for the S.Tech drop and spring rate. They might be overly firm for them. Haha. Rebound might be too firm. I don't track my cars either, but drive on some really sh itty roads.
Old 06-14-2018, 10:44 AM   #5
ern-diz
ern-diz's Avatar
Good to know, thank you.
On Instagram
On Wheelwell
Please post pics of your Yaris with aftermarket rims here grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1800 11-12-2025 12:57 PM
TRD Sport Shocks, Lowering Springs & Sway Bar Blue Beast Cosmetic Modifications (Exterior/Interior) 18 10-29-2012 04:39 AM
fs stock springs and struts, shocks XyresicPsych Items for Sale by private party 10 05-04-2012 08:34 PM
for trade lowering springs for stock rs 2007 mfvantol Items for Sale by private party 5 09-24-2011 08:30 PM
TTE / Eibach springs + stock shocks & 15" wheels DieselPower Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 07-11-2009 02:42 PM
