![]() ![]() ![]() Drives: 1987 Silverado Join Date: Jan 2010
Squishy brake pedal. But no fluid change or drain
The dealership wanted $230 to maintenance my rear brakes on my 2009 sedan. So I did it myself instead. Got new brake shoes, springs, and drums installed. Saved me about $100 doing it myself.
Only thing is, now I have a squishy brake pedal that isn't as firm as it was before. Anyone know why? Is it because the new brake shoes need time to self adjust? Maybe there is too much of a gap between the shoe and the drum? I did not have to do anything with the fluid. What do I need to do to get the firm brake pedal to return? |
How many clicks does your e brake have before you cannot pull it up anymore?
Adjust up the star wheel at each brake 1st. You should have a slight drag on the drum.
I agree with ex fire. After you adjust the brakes with the star through the hole at the top inside of the brake assembly, I would Bleed them. And while you’re doing that you might just as well use the entire can of brake fluid to change the brake fluid out in the car. Good luck and tell us what happens!
they aren't reverse threaded per se. spin them one way and it pushes both drum pads out, and spin them the other they come in..
BUt also check your handbrake setting. |
You can only spin the star wheel one way. The system locks it from going the wrong way and loosening (assuming you installed them properly)
I'd recommend just taking the wheel off and drum off to do it. You will frustrate yourself beyond all belief trying to do it from the little hope in the back
When I was playing with that a year ago I was simply not able to move the starwheel in neither direction. It was completely stuck (drum was off).
As the brakeshoes position was nearly perfect (I wanted to add one click to increase the friction a bit) I simply gave up. Nowadays I am thinking of revisiting this as I do not want to be beaten by that freaking piece of metal!
#9 | |
Had a 2001 Volvo S80 I feel the same way about. Can ran like poop, until you cleared the check engine codes. Then it ran great. 15 minutes later it ran like poop again, with black smoke coming out the back. Ended up just selling the car. But I want another crack at it! I can fix it! |
15 clicks is way too many, it means you need to adjust your star adjuster to tighten the shoes to the drum. This is why your brake pad feels soft. That causes this effect on the Yaris
#11 | |
And I do have to ask the question: I thought they were supposed to be "self adujusting". As in, they'd finally adjust themselves even if it took awhile. Maybe the self adjusting part only works within a certain limited range? |
#12 | |
3 clicks. Sent from my Elite_5_5_Octa using Tapatalk
yyou could upgrade to discs and save yourself the headache of drums/
#15 | |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
Proper way to adjust the rear drums is to keep increasing tension untill the wheel begins to drag when you try to spin it with the drum on and the parking brake off. |
#16 | |
![]() ![]() Drives: 07 Yaris Liftback Join Date: Nov 2010
I'm going to guess some how air got into the system. Not really sure how that's possible, but a squishy brake pedal is a sign of air being in the system.
Do a brake fluid flush with some DOT3/4 fluid, and see how it feels then. It's probably due for a flush anyway. I'll be flushing mine (probably with the gravity method unless I can have someone help me by pressing on the brake pedal) soon. I've flushed it once already, but I used Torque RT700 (DOT4), but it's changed color quickly (even became a little jelly in my FR-S [sucked out and topped off with new fluid for now]). I have some Amsoil DOT3/4 waiting for both cars, just need the time to do it. |
#18 | |
| Mysterious Brake Fluid Loss | xdarkxfirex | DIY / Maintenance / Service | 5 | 09-30-2017 09:18 PM |
| 98k mile A/T fluid change and it's wierd?!? | 07stlYaris | DIY / Maintenance / Service | 6 | 10-11-2014 02:38 PM |
| Should I change my brake fluid? | lh59 | DIY / Maintenance / Service | 4 | 06-27-2012 12:48 AM |
| Brake lines/brake fluid change out | jstantherprsn | DIY / Maintenance / Service | 3 | 11-02-2010 12:53 PM |
| Anyone have their brake pedal go rock hard on hot days? | LtNoogie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 07-28-2009 12:20 PM |
