Old 08-30-2018, 04:01 PM   #11
B.B._07
Drives: 07 5dr
Originally Posted by ojeysky View Post
Anyone with a response? @CTScot, kindly help with this question. Should I be getting ambient temperature data from my scanner when the sensor itself is not connected?
Without the ambient temp sensor connected any ambient temp reading you get on the scanner is worthless. The 81C reading you're seeing is probably a default value the car's ecu is using given that it's only seeing an open circuit on the ambient temp sensor circuit.
Bad Air/ Fuel mixture sensor warning for ALL Yaris owners eric81 General Yaris / Vitz Discussion 31 04-21-2012 08:28 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
Bad Speed Sensor? dmehak DIY / Maintenance / Service 33 01-05-2011 09:17 PM
Coolant Temp Sensor location? Yeti DIY / Maintenance / Service 7 05-06-2009 10:13 AM
outside temp on cluster??? ae92trueno7 Cosmetic Modifications (Exterior/Interior) 11 01-01-2009 10:36 PM
