Old 05-05-2009, 09:49 AM   #1
Yeti
Drives: 1999 Silver Yaris SR
Coolant Temp Sensor location?
HI, just been given (free) a 1999 Yaris SR (UK model).
It runs like a bag of spanners when it's cold, but once it heats up it's fine - whcih leads me to believe that the coolant temp sensor (connected to the ECU) is faulty - but where is it?
Can anyone tell me please? Thanks.
Yeti is offline   Reply With Quote
Old 05-05-2009, 09:53 AM   #2
I am no mechanics, but have you checked all the components? i mean.. air filter, spark plugs, o2 sensors, MAF?
What does it mean to run like a bag of spanners? Is it automatic or manual ?
Old 05-05-2009, 10:22 AM   #3
Yeti
Yes, I've checked all that - I AM a mechanic! It's had new plugs, air filter, cleaned the throttle body etc.
It's a manual - but even without driving it it runs lumpy, misfires and smokes (unburnt fuel) until it's warm.
I'm 100% sure it's the coolant temp sensor - I just don't know where to find it - there's 2 sensors down the flywheel side of the head - one has 3 wires and one has 2. Don't know which one it is - if I know, I can unplug it and use a variable resistor to mimic the temp sensor - and then order one from the dealer for it.
"Runs like a bag of spanners" means it's running like crap!
Old 05-05-2009, 12:55 PM   #4
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
For the USDM, 1NZ-FE the coolant sensor is on the top right of the head. Hope this helps.
Old 05-05-2009, 01:06 PM   #5
if it's lumpy and misfires, have you checked the coil packs ?
It's hard to believe how a coolant temp sensor could affect the car to cause such troubles. Also, if you have the 1.3L or a 1.0L, it would be very hard for us to help, as we only have the 1.5L engine in our yarii.
Old 05-06-2009, 07:43 AM   #6
Yeti
It's a 1.3. I changed the coolant temp sensor this morning, and no difference. :-(
MAF maybe? The ECU warning light is on - anyone know where I can get software that will read the codes? I have an OBDII interface for the serial port on the PC, but no software.
Old 05-06-2009, 08:31 AM   #7
The check engine is probably throwing a misfire code on one of the cylinder.
I'm repeating myself, Have you check the coil packs?? You are a mechanics, you should be able to diagnose which cylinder is malfunctioning.
try this for the PC ODBII reader.
http://obddiagnostics.com/ProgWin.html
Old 05-06-2009, 10:13 AM   #8
Yeti
Just checked with my mate there - he changed the plugs, but not the coil packs - trying to borrow another Yaris to swap the coil packs over - I'll bring the OBD cable in tommorrow and try that software you gave me the link to, thanks.
Help ASAP!!!! low coolant indicator MeggiemobileSFLA DIY / Maintenance / Service 29 08-03-2013 01:09 AM
Coolant Service N9QGS DIY / Maintenance / Service 31 11-27-2012 06:55 AM
Inlet air temp vs. vehicle speed LtNoogie Performance Modifications 8 04-27-2009 12:20 AM
outside temp on cluster??? ae92trueno7 Cosmetic Modifications (Exterior/Interior) 11 01-01-2009 10:36 PM
Engine Coolant Temperature djino General Yaris / Vitz Discussion 18 07-16-2007 12:26 AM
