![]() Drives: 07 5 door hatchback Join Date: Oct 2018
My sensor pin was broken
I should mention that my sensor pin was broken and the connector was also broken, but there was no corrosion because the car was not driven in the winter.
The plastic of the connector was broken for some unknown reason and I will take a picture of it next time I remove it to replace the parts. |
| Can't find front hub bearing assembly with ABS anywhere! | PrettyWreckless | DIY / Maintenance / Service | 5 | 04-09-2018 03:15 PM |
| abs rear hub assy and sensor change + new harness install. | limochong | DIY / Maintenance / Service | 2 | 11-13-2014 04:58 AM |
| Disconnecting rear hub ABS | 746watts | DIY / Maintenance / Service | 4 | 04-17-2012 03:23 PM |
| yaris hub and bearing assy with abs | chrissy b | Items for Sale by private party | 8 | 12-12-2011 09:22 AM |
| What's with ABS? | jgag123 | Canada | 9 | 01-01-2009 06:04 PM |
