These are available on eBay:
https://www.ebay.com/itm/ABS-Wheel-S....c100506.m3226 Also available on Rock Auto: https://www.rockauto.com/en/catalog/...ed+sensor,1912 Apparently Toyota also has one available: https://parts.southern441toyota.com/...rol-8954452040
| Can't find front hub bearing assembly with ABS anywhere! | PrettyWreckless | DIY / Maintenance / Service | 5 | 04-09-2018 03:15 PM |
| abs rear hub assy and sensor change + new harness install. | limochong | DIY / Maintenance / Service | 2 | 11-13-2014 04:58 AM |
| Disconnecting rear hub ABS | 746watts | DIY / Maintenance / Service | 4 | 04-17-2012 03:23 PM |
| yaris hub and bearing assy with abs | chrissy b | Items for Sale by private party | 8 | 12-12-2011 09:22 AM |
| What's with ABS? | jgag123 | Canada | 9 | 01-01-2009 06:04 PM |
