Old 11-12-2018, 03:33 PM   #1
DarkShadowFox
Originally Posted by Jason@SportsCar View Post
The ARP kit uses the same tool as the OE head bolts, you grid the nut down you lose the ability to use the tool. The ARP stuff is crazy long, and the Jun flanges are massive, its not even close.
Even if you want to use ARP's with stock cams you have an issue with the VVTi solenoid, its passage is blocked by one of the studs. Poorly designed kit.
go custom. this really isnt a race engine i think they expect you to remove things like that when installing kits like this and go full race cams and run at full or 80% all the time like on a race track.
kinda like the TRD 4AGE but the economy version.
Old 11-12-2018, 06:15 PM   #2
Jason@SportsCar
Now I cant tell if you are serious or just trolling.
I spoke to ARP as soon as we discovered the issue. They built the kit to fit the stock engine, and they did so because an overseas customer put in an order for 50 kits. They claimed to have never had an issue reported to them. Clearly they never test fitted the kit on a stock engine during R&D, the VVTi interference is a pretty major oversight. If you sell a part to fit a stock engine it should fit. But somehow they almost never do.
When I sent them images they could not deny the fitment issue, and the only response was to use a stock bolt in that location. Duh.
They don't do one-offs, you want a set made you have to order enough to make it worth the machine time. Closest thing you get to one-off is finding parts that can be "made to fit". This is what Garm did many years ago when he built his turbo engine. This required having the block machined to fit a different kit. Not unusual when building a race engine - but again, if they are selling a kit to fit that engine it should actually fit that engine.
I have no need to come up with a "custom solution" at this point, happy to have a partial ARP kit in place, so we only have to waste three OE bolts when we tear down the engine.
JUN Auto high lift cams question Innovative 1 Performance Modifications 14 02-11-2021 02:15 PM
Whiteline Control Arm Bushing install and Review tmontague Performance Modifications 3 06-08-2019 02:42 AM
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
JUN Cams for 1NZ-FE Dylan Yap Performance Modifications 29 05-11-2011 02:58 PM
