#1 | |
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
kinda like the TRD 4AGE but the economy version. |
#2 | |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
![]() I spoke to ARP as soon as we discovered the issue. They built the kit to fit the stock engine, and they did so because an overseas customer put in an order for 50 kits. They claimed to have never had an issue reported to them. Clearly they never test fitted the kit on a stock engine during R&D, the VVTi interference is a pretty major oversight. If you sell a part to fit a stock engine it should fit. But somehow they almost never do. When I sent them images they could not deny the fitment issue, and the only response was to use a stock bolt in that location. Duh. They don't do one-offs, you want a set made you have to order enough to make it worth the machine time. Closest thing you get to one-off is finding parts that can be "made to fit". This is what Garm did many years ago when he built his turbo engine. This required having the block machined to fit a different kit. Not unusual when building a race engine - but again, if they are selling a kit to fit that engine it should actually fit that engine. I have no need to come up with a "custom solution" at this point, happy to have a partial ARP kit in place, so we only have to waste three OE bolts when we tear down the engine.
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 09:14 PM |
| JUN Auto high lift cams question | Innovative 1 | Performance Modifications | 14 | 02-11-2021 03:15 PM |
| Whiteline Control Arm Bushing install and Review | tmontague | Performance Modifications | 3 | 06-08-2019 03:42 AM |
| Lower alternator bolt won't go back in, help! | Tmblackflag | DIY / Maintenance / Service | 3 | 01-21-2013 04:18 PM |
| JUN Cams for 1NZ-FE | Dylan Yap | Performance Modifications | 29 | 05-11-2011 03:58 PM |
