Old 11-17-2018, 01:04 PM   #28
Hamster
Hamster's Avatar
Drives: 2009 5-Door Liftback
Thanks 06YarisRS! Sounds as simple as an oil change, minus the jacking up. I've always done my own oil changes. So if some maintenance item is a simple as a drain and refill, I am confident that I can do it.
With such low mileage on my car and very clean looking ATF, will a simple drain and refill be sufficient for keeping my transmission in top condition? Previous replies discussed dropping the pan, replacing the filter, etc. Is that only necessary if the the car has problems, or if the ATF was neglected and comes out brown and dirty? Just wondering.
Hamster is offline   Reply With Quote
Can non-Toyota dealers/repair shops replace transmission fluid w/o "special equipment lejulie DIY / Maintenance / Service 10 10-23-2011 08:35 PM
So when DOES the transmission fluid need to be changed dutchy999 DIY / Maintenance / Service 12 09-06-2011 06:18 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 03:52 PM
wrong transmission fluid? supmet DIY / Maintenance / Service 14 02-19-2009 05:01 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 05:25 PM
