#28 |
![]() ![]() ![]() Drives: 2009 5-Door Liftback Join Date: Jun 2011
Thanks 06YarisRS! Sounds as simple as an oil change, minus the jacking up. I've always done my own oil changes. So if some maintenance item is a simple as a drain and refill, I am confident that I can do it.
With such low mileage on my car and very clean looking ATF, will a simple drain and refill be sufficient for keeping my transmission in top condition? Previous replies discussed dropping the pan, replacing the filter, etc. Is that only necessary if the the car has problems, or if the ATF was neglected and comes out brown and dirty? Just wondering. |
| Can non-Toyota dealers/repair shops replace transmission fluid w/o "special equipment | lejulie | DIY / Maintenance / Service | 10 | 10-23-2011 07:35 PM |
| So when DOES the transmission fluid need to be changed | dutchy999 | DIY / Maintenance / Service | 12 | 09-06-2011 05:18 PM |
| wrong transmission fluid? | supmet | DIY / Maintenance / Service | 14 | 02-19-2009 04:01 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
