Old 12-07-2018, 08:25 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
A/C Woes - Opinons/Guidance Welcomed
DANG! May need yet another A/C compressor!
After my swap, obviously I needed to do some A/C work. I replaced the compressor with a used one and it turned out to have a noisy bearing, so back it went. The 'new' used one runs very quiet, but may have problems.
Below is my thought process.
As far as servicing the system, I followed the ChrisFix youtube video to the letter. I will say that there was some leaking around my manifold gauge fittings while filling with R134 despite properly tightening the fittings (firmly tight by hand/snug)
https://www.youtube.com/watch?v=Pdq8JAlct6s
The system held vacuum over night, so I was pretty sure it was leak free.
Put 1.3 cans of R134 (~16 oz) into the system.
Here is a pic of my readings - basically high presure on the LOW side, low pressure on the HIGH side. According to the tables below my pic, high pressure on the LOW side and low pressure on the HIGH side might suggest a faulty compressor.
Open to guidance. I would really like to do this myself, not be defeated and have to go to an A/C shop.
With Engine Off: ~55psi LOW side and ~42 psi HIGH side
With Engine Running: ~50psi LOW side and ~40psi HIGH side
A/C on and set to coldest position. Ambient temp was probably around 50F in my garage, so I had to do a bit of extrapolation.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 07:57 AM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 04:33 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
