What was the ambient temps when you did this? Works best in hot summer temps. Iirc the fill is about 12 ounces not 16 but I could be wrong.
When I recharged mine it was winter, I disregarded the pressure readings as they will read low and not accurate when not in warm temps. I rechecked them once summer came and everything turned out fine. My advice- fill the system to the proper amount after checking that there are no leaks. Leave it until summer and then recheck pressures or just check to make sure if blows cold, if it does then you're good to go
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| A/C Clutch Compressor question | tmontague | DIY / Maintenance / Service | 3 | 05-11-2014 07:57 AM |
| A/C Broken On My 2010 5 DR HB | ChilliwackGuy | DIY / Maintenance / Service | 15 | 07-14-2010 04:33 PM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
