Old 12-08-2018, 10:38 AM   #7
tmontague
tmontague's Avatar
What was the ambient temps when you did this? Works best in hot summer temps. Iirc the fill is about 12 ounces not 16 but I could be wrong.
When I recharged mine it was winter, I disregarded the pressure readings as they will read low and not accurate when not in warm temps. I rechecked them once summer came and everything turned out fine.
My advice- fill the system to the proper amount after checking that there are no leaks. Leave it until summer and then recheck pressures or just check to make sure if blows cold, if it does then you're good to go
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 07:57 AM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 04:33 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
