Old 12-11-2018, 06:46 PM   #11
atomic_hoji
Drives: 2018 Yaris SE 5MT
Well, so much for troubleshooting - there's yer problem: refrigerants on the outside! Heh. Joking aside, on the bright side at least you have a good idea what the pressure drop is being caused by. Some new o-rings should help.
If you haven't already, as a quick note, especially if you decide to replace the condenser, if the system has been open a while a new drier desiccant bag is fairly cheap (as I recall) and will capture any moisture in the system after your refill.
-- Adam
atomic_hoji is offline   Reply With Quote
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 07:57 AM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 04:33 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
