0-60 in slow
Gotta be careful about what ECU's you run, not all of the support the Toyota Cam\Crank timing. I know that my AEM series 2 will do dual VVT, but in your situation with the EMS-4 I'd just leave the exhaust cam controlled by the stock ECU.
2014 BSpec Divisional Champion |
#2 | |
Does the stock ecu need the MAF signal to run the throttle? and can the factory ecu control the dual vvti without having all of the other sensors connected (ie: fuel, ignition, cam,crank)? The infinity almost doubles the price and not sure if that would be worth it just for throttle control. EDIT* I think a smart next step foir me would be to find a tuner within my area that deals has experience with 4 bangers and Toyotas and ask what they recommend. At the end of the day, they will be tuning it so the more comfortable they are with the software and ecu, the better
#3 | |
0-60 in slow
It needs the MAF singnal or it it goes into limp mode and doesn't allow more than 20% throttle, you'll either need to add another MAF sensor or add a MAP sensor, I went the MAP route. You'll want to control the intake cam as there is alot of power to be had there, and I think the EMS-4 is very capable of doing that. But yeah if you didn't want to wire those up you can easily have the stock ecu control vvt, but it may start doing weird things trying to learn its way out of not being able to control spark or fuel. You'll also want to wire the knock sensor up to the new ECU since its going to be controlling spark and fuel. All of the ECU's are pretty much the same in regards to tuning, at least thats what my tuner tells me, but they prefer tuning with Motec but I can't swing the 3-4k for one of those. I think the EMS-4 should be more than capable of doing what you're asking, since I'm sure there isn't much power to be had messing with the exhaust cam, I even think MWR sells a ecu kit for the corolla that uses this ECU, but I'm not sure the wiring is the same for the XD as it is for the corolla.
#4 | |
How bad is the idle with the set up?
#5 | |
0-60 in slow
#6 | |
To fix my idle I drilled an 1/8" hole in the butterfly - started smaller and worked up to a spot where the car wouldn't die.
| Standalone in Parallel with stock ECU | tmontague | Performance Modifications | 8 | 02-10-2016 10:13 PM |
| standalone and stock ecu | Radou | Performance Modifications | 0 | 06-16-2013 04:47 PM |
| aem EMS-4 standalone ECU | maxthehax | Forced Induction Forum | 19 | 05-23-2013 11:29 AM |
| Standalone ECU | d1nzfe | Performance Modifications | 11 | 12-24-2009 11:46 AM |
| FS: Motec M4 Standalone ECU w/ Ignition Expander | Biggie™ | Items for Sale by private party | 6 | 10-20-2009 02:36 PM |
