Old 01-03-2019, 02:42 PM   #9
tmontague
tmontague's Avatar
Originally Posted by xnamerxx View Post
It needs the MAF singnal or it it goes into limp mode and doesn't allow more than 20% throttle, you'll either need to add another MAF sensor or add a MAP sensor, I went the MAP route. You'll want to control the intake cam as there is alot of power to be had there, and I think the EMS-4 is very capable of doing that. But yeah if you didn't want to wire those up you can easily have the stock ecu control vvt, but it may start doing weird things trying to learn its way out of not being able to control spark or fuel. You'll also want to wire the knock sensor up to the new ECU since its going to be controlling spark and fuel. All of the ECU's are pretty much the same in regards to tuning, at least thats what my tuner tells me, but they prefer tuning with Motec but I can't swing the 3-4k for one of those.
I think the EMS-4 should be more than capable of doing what you're asking, since I'm sure there isn't much power to be had messing with the exhaust cam, I even think MWR sells a ecu kit for the corolla that uses this ECU, but I'm not sure the wiring is the same for the XD as it is for the corolla.
I plan on going the MAP route as well, and i definitely don't trust the ecu ton control vvti without receiving all of the other inputs. I am going to look into the EMS4 some more and potentially plan to have it control the vvti at leats on the intake side if it cannot do both. I hope to use the stock ecu just for throttle and leave it hooked up to the MAF.
How bad is the idle with the set up?
Standalone in Parallel with stock ECU tmontague Performance Modifications 8 02-10-2016 10:13 PM
standalone and stock ecu Radou Performance Modifications 0 06-16-2013 04:47 PM
aem EMS-4 standalone ECU maxthehax Forced Induction Forum 19 05-23-2013 11:29 AM
Standalone ECU d1nzfe Performance Modifications 11 12-24-2009 11:46 AM
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
