Afaik they are synonymous. Keep in mind you may have issues getting the old one out of the head. If that happens the worst case scenario is you can take off the valve cover and use a punch to push it out from the inside. Take more time but saves you from a trip to the mechanic.
When pulling it out from the outside it often comes apart and then you dont really have much the pull on anymore, just an fyi
#2 | |
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Oct 2017
| Check Valve Timing (On timing chain) | EMT with a Yaris | DIY / Maintenance / Service | 9 | 11-17-2018 03:29 AM |
| Valve timing help | Sakis Deme | General Yaris / Vitz Discussion | 0 | 10-17-2017 08:47 AM |
| Question replacing head gasket. | Snyprwlf47 | DIY / Maintenance / Service | 3 | 07-13-2014 11:17 PM |
| Variable Valve Sensor Error | Craig | DIY / Maintenance / Service | 13 | 06-22-2013 03:29 AM |
