Old 02-01-2019, 09:15 AM   #1
Leegamer
Leegamer's Avatar
Drives: No longer own a yaris :(
the more EVs there are, the more combustion engine cars I'll buy and put straight pipes on.
I'm a hermit named Lee
Leegamer is offline   Reply With Quote
Old 02-01-2019, 10:04 AM   #2
myfirstyota
3 Yaris and counting..
I like your style Lee!
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 02-01-2019, 01:12 PM   #3
Leegamer
Leegamer's Avatar
The dude abides!
Old 02-01-2019, 05:25 PM   #4
suprf1y
suprf1y's Avatar
Drives: 05 Echo
In an effort to get as light as possible I used to run a Lithium ion battery in one of my previous cars. It was technically a summer only car but I drove it as long as there was no snow or salt on the road. It got pretty dicey in late November/early December after a 12hr night shift. It always started, but since they regain voltage as they heat up, I often had to short crank it 3-4 times to let the battery heat before it would actually turn it fast enough to start.
suprf1y is offline   Reply With Quote
Old 02-01-2019, 07:29 PM   #5
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Anyone had a look at the "Rescue Mate" jump starter? http://www.rescue-mate.com
This uses capacitors instead of lithium batteries, and charges from the residual power still in the car battery.
Old 02-01-2019, 07:58 PM   #6
tmontague
tmontague's Avatar
Hmm, interesting, never thought about warming it up that way
I've seen videos online about it. Seems like a brilliant idea for those in cold climates. Realistically I can bring my jumper inside with me during the winter when I'm at work or over night, but it is a hassle and the capacitor solution would allow you to leave it in your car all winter until you need it
Old 02-01-2019, 08:22 PM   #7
suprf1y
suprf1y's Avatar
Drives: 05 Echo
Let's see if this works. EDIT: Photobucket's back I guess
Perspective
It was starting a 12.5-1 G13 with about 250 psi craking pressure
We Have the Beats! ern-diz Photo-Video-Media Gallery 41 05-15-2018 05:58 AM
Battery question - jump starting and hooking up new accesories funky2nite Third Gen Yaris General Discussion 1 06-23-2017 09:29 PM
Buying aftermarket battery caineroad DIY / Maintenance / Service 57 02-14-2016 07:17 AM
What's the longest a car can sit without running before its' battery needs a jump? SilverBack Off-topic / Other Cars / Everything else Discussions 21 06-10-2010 04:55 PM
