![]() ![]() Drives: 05 Echo Join Date: Jul 2009
In an effort to get as light as possible I used to run a Lithium ion battery in one of my previous cars. It was technically a summer only car but I drove it as long as there was no snow or salt on the road. It got pretty dicey in late November/early December after a 12hr night shift. It always started, but since they regain voltage as they heat up, I often had to short crank it 3-4 times to let the battery heat before it would actually turn it fast enough to start.
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
Anyone had a look at the "Rescue Mate" jump starter? http://www.rescue-mate.com
This uses capacitors instead of lithium batteries, and charges from the residual power still in the car battery.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#3 | ||
Let's see if this works. EDIT: Photobucket's back I guess
![]() Perspective ![]() It was starting a 12.5-1 G13 with about 250 psi craking pressure |
| We Have the Beats! | ern-diz | Photo-Video-Media Gallery | 41 | 05-15-2018 05:58 AM |
| Battery question - jump starting and hooking up new accesories | funky2nite | Third Gen Yaris General Discussion | 1 | 06-23-2017 09:29 PM |
| Buying aftermarket battery | caineroad | DIY / Maintenance / Service | 57 | 02-14-2016 07:17 AM |
| What's the longest a car can sit without running before its' battery needs a jump? | SilverBack | Off-topic / Other Cars / Everything else Discussions | 21 | 06-10-2010 04:55 PM |
