Old 06-14-2019, 11:51 PM   #1
nashyaris
Drives: 2008 Yaris
Worked for me!
Originally Posted by vinooooo93 View Post
Might be different colour to mine but here is the diagram that shows position of positive and negative cables (Terminal 5 and 6 for Sedan respectively).
Always best to confirm positive wire with current tester when gear is put in reverse - should light up. Hope this helps
I used a test light and hooked it up to wire 5 positive (brown) and wire 6 negative on the rear drivers side light on a 2008 Yaris sedan - this was the correct reverse wire! Hooked up the backup camera like pro. Thanks for help y'all!
nashyaris is offline   Reply With Quote
Wires Inside the Yaris & What They Do The Architect DIY / Maintenance / Service 149 10-18-2022 03:32 AM
Light Bulb Specs? Violin DIY / Maintenance / Service 34 12-06-2018 05:09 PM
03 Yaris Dome light help GoldenMonkey93 DIY / Maintenance / Service 6 11-13-2014 03:06 PM
Changing Map Light Bulb justin27zamora DIY / Maintenance / Service 2 06-19-2013 11:07 AM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
