Old 06-16-2013, 01:52 AM   #1
justin27zamora
Drives: Toyota Vios 2012
Changing Map Light Bulb
I want to change my map lights bulb but there is no step-by-step instruction on the car's manual. Is there anyone who already change these? I don't want to change it without a correct instructions because it might broke something. Thanks in advance.
justin27zamora is offline   Reply With Quote
Old 06-18-2013, 11:22 PM   #2
clarenceie
Drives: Yaris Sedan
I assume this is a US Yaris 08-12. Pry one of the clear covers from the middle with a flathead screw driver. It takes T10/194/168 bulbs, pull out the bulb. push the new one in (polarity does not matter).
Let's assume u took out the driver's side. to put on the cover, u would slide in the left side of the cover first, then push the right side of the cover to lock it into the pegs.
clarenceie is offline   Reply With Quote
Old 06-19-2013, 11:07 AM   #3
RedRide
RedRide's Avatar
Clarenceie is correct. I would just add that you should be sure to pry the lens (cover) out "gently".
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 12:02 PM
Light bulb questions Yaris_80 DIY / Maintenance / Service 4 07-16-2013 12:36 PM
Light Bulb Numbers For Interior Illumination privateyeblckbx Cosmetic Modifications (Exterior/Interior) 0 05-16-2010 04:59 AM
anyway of taking out the abs light bulb? SweetRS DIY / Maintenance / Service 2 03-13-2009 08:24 PM
MAP LIGHT drell42 Cosmetic Modifications (Exterior/Interior) 2 05-21-2007 07:30 PM
