Old 06-28-2019, 09:08 PM   #1
white89gt
Drives: 07 Yaris Hatch
Thanks for the reply. I did look at STFT and LTFT, and they were good.
I'm going to have to get creative with my FP gauge I guess. Not too sure why Toyota couldn't make it easy.
white89gt is offline   Reply With Quote
Old 06-29-2019, 05:50 AM   #2
zoidberg444
zoidberg444's Avatar
Well i can understand US domestic brands having them because they have such poor build quality that the dealer techs will probably have to check the fuel pressure when the vehicle is under warranty.
The Yaris is built on a budget and how often do the fuel pumps or injectors go bad?
Sent from my SM-G965F using Tapatalk
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles
UK to Nordkapp in a Yaris
Old 06-29-2019, 09:33 AM   #3
tmontague
tmontague's Avatar
This is true, but definitely frustrating for a diy'r when you want to rule out fuel issues. Fuel is rarely an issue with toyota engines, typically coil packs are tje cause of misfires in high mileage engines
Old 06-29-2019, 10:56 AM   #4
zoidberg444
I saw it happen to my cousins Yaris. She had a 2SZ engined one. I'm not sure if it was a chicken or egg problem but she had coils 2 and 3 fail at the same time and i think new plugs as well at the dealer. I wondered what had gone bad first. Bad plugs damaging the coils or bad coils that fried the plugs?
Old 07-01-2019, 09:38 AM   #5
white89gt
Say what you want about domestics, but at least you can repair them. I have had to do very little to this Yaris at 160K miles, but I can also say the same about my F150 with 260K on it. In fact, I've never had to check FP on the F150 - but I need to on the Yaris, so...
Originally Posted by ex-x-fire View Post
Melted electrodes? You think you'd have some codes.
I did, it had a cylinder 2 misfire. I had absolutely no signs whatsoever of it running differently until that point either. BUT, all four plugs looked the same - which is what I think it is running lean. Maybe the Denso plugs were not that good though... I put NGK's back in it.
I actually found a gauge that is supposed to allow you to disconnect the fuel line from the fuel rail, and then the gauge has connections to go between. Have to wait for it to get here though.
Check Your Spare Tire Pressure Bluevitz-rs DIY / Maintenance / Service 7 10-22-2016 02:30 PM
"5 Driving Myths That Cost You Money" PETERPOOP Fuel Economy Forum 10 05-24-2011 10:20 PM
Fuel Pressure Regulators and setting meters? Nagoya_TRD. Forced Induction Forum 21 05-15-2009 11:14 AM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
