Old 10-21-2016, 11:54 PM   #1
Exclamation Check Your Spare Tire Pressure
When was the last time you check that neglected spare tire under the floor in the trunk? I see mine on a regular basis but never think to check the pressure in it. So one day I had the floor out and happened to be checking and topping up all the rest of the tires in the family fleet and thought I should probably check that spare air.
It only had 10lbs in it. I think that was the 2nd time I've ever checked it in 11 years. So I blew it up to 60 as marked on the tire. Because it would really suck if you went through all the trouble of changing a tire on the side of the road only to have you spare flat too.
Old 10-22-2016, 01:10 AM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Ha! I just did the same thing yesterday. I had never aired it up in the 2 1/2 years since I bought it. Was at 20psi. Pumped it up to 60.
Old 10-22-2016, 01:40 AM   #3
Good tip
I got into the habit of checking it when I rotate my tires every oil change (15000km)
When I bought my Vibe it only had 20psi in the rear so I filled it up to 65 (always go a bit above since I don't check the pressure every month). The week later my wife drive over metal shards and got a flat...
Old 10-22-2016, 07:43 AM   #4
bronsin
bronsin's Avatar
Good idea! Since the tire is upside down get an extension of the tire valve so you dont have to remove the tire for the check.
Old 10-22-2016, 12:40 PM   #5
NYC-SE
NYC-SE's Avatar
That's the reason I hadn't checked it before. Stupid and lazy I know. But really why did Toyota choose to mount it this way? Don't they know there are plenty of stupid and lazy people out there.
Old 10-22-2016, 12:42 PM   #6
In my Echo it's right side up. Makes it easy to check.
Old 10-22-2016, 01:09 PM   #7
SirDigby
Drives: 2007 yaris 3 door
it should be checked every time you service the vehicle. at least every time you rotate/swap tires. (winter/summer) you should have learned this when you got your license.
Old 10-22-2016, 02:30 PM   #8
Upside down gives you more usable space in that compartment to put things like jumper cables and/or a quart of oil. I use that space in most cars I own.
Check it every 6months or slightly over inflate and check once a year and you should be fine if you ever need it
spare tire
Best tire pressure for Fuel Economy edmscan Fuel Economy Forum 28 12-05-2012 10:55 PM
Spare tire question...................... NEexpat General Yaris / Vitz Discussion 9 08-23-2012 07:29 PM
tire pressure walt101786 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 03-01-2011 04:20 PM
tire pressure light goes on and off, on and off janices_yaris DIY / Maintenance / Service 8 07-30-2010 03:58 AM
