Old 05-12-2009, 04:42 PM   #1
Nagoya_TRD.
Drives: None.
Fuel Pressure Regulators and setting meters?
I just trying to learn a little more about fuel systems, but i have an idea what the regulator does. What is the point of the "setting meter" other than showing the fuel pressure?
http://www.more-japan.com/product.ph...cat=539&page=1
In this case, let's talk about SARD Fuel pressure regulators and their "setting" guage.
Someone explain this part of fuel systems to me. Thank you.
Nagoya_TRD. is offline   Reply With Quote
Old 05-12-2009, 06:43 PM   #2
The gauge shows the pressure visually so you can make adjustments quickly, without having to read it from management software, etc.
Old 05-14-2009, 01:43 PM   #3
Nagoya_TRD.
Drives: None.
Will this work only for the Sard FPR or others as well?
Old 05-14-2009, 02:10 PM   #4
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
im assuming its universal and you can tap it in anywhere....
Old 05-14-2009, 02:39 PM   #5
A gauge is a gauge, as long as the fittings work. We ended up putting my gauge at the end of the fuel rail - no need for a line or a bracket that way.
Old 05-14-2009, 02:56 PM   #6
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
The gauge shown appears to be the one used to set the fuel pressure on the dyno while tuning and not one you'd have installed constantly (or be able to view constantly since it's in the engine bay).
a standard (electronic) gauge has a sensor attached to a sending unit which then sends the data into the gauge in the cabin.
so yes there is a difference between a standard electronic fuel pressure gauge and the "setting" fuel pressure gauge.
Russelt3hPirate is offline   Reply With Quote
Old 05-14-2009, 04:53 PM   #7
I have a regulator (which sets the pressure) and a liquid-filled gauge off the fuel rail, in the engine bay. I'm assuming it's a mechanical gauge.
Old 05-14-2009, 04:59 PM   #8
Russelt3hPirate
l33t3st Asshole
yeah the gauge in the first post and link is the same idea as the one on your fuel rail.
simply for setting the fuel pressure, not for monitoring fuel pressure.
Old 05-14-2009, 05:04 PM   #9
well, if you sat on the valve cover and leaned way over, mayyyybeeeee you could watch it
Old 05-14-2009, 05:13 PM   #10
Russelt3hPirate
l33t3st Asshole
wait, you can't see yours even when the hood is up without sitting on the valve cover?
what's the point if you can't see it?
Old 05-15-2009, 12:24 AM   #11
Here's my set up:
Old 05-15-2009, 12:42 AM   #12
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Garm, what pressure are you setting your system to at idle? Is your regulator boost compensating?
Old 05-15-2009, 09:33 AM   #13
No, it's a fixed pressure. It's the injectors job to squirt the correct amount of fuel. We have it at 40 right now, but if the injectors max out we may end up with a higher pressure. Not done tuning yet!
Old 05-15-2009, 10:01 AM   #14
Russelt3hPirate
l33t3st Asshole
Originally Posted by cdydjded View Post
Our cars use what called a "returnless fuel system". The regulator is in the fuel tank, not on the fuel rail. It is not adjustable. You would have to convert to a "return" fuel system to be able to adjust your fuel pressure. Unless you are running a S/C or turbo you fuel pressure does not have to be adjusted, even with all the bolts on's available for our cars.
hmm, converting to a return fuel system would be entertaining.
might as well gut the car, ligthen the wiring, and re do the ENTIRE fuel system while you're at it....
research time.
Old 05-15-2009, 10:22 AM   #15
Russelt3hPirate
l33t3st Asshole
converting to a returnless system is common modification on the SRT4 for example. This mod for the SRT4 makes 30-35 more hp. I dont know what your comment about "gutting the car" & "ligthen the wiring" means, converting to a return system does involve " re doing the Entire fuel system" I dont need any "reseach time" Iv done this many times. I can send you a details if you want
I'm interested in what's involved. It'd save me some time.
reason I said the other two things, is I'd like to do those at the same time.
Old 05-15-2009, 10:48 AM   #16
Russelt3hPirate
l33t3st Asshole
OK here is a list of parts:
Fuel rail (Perrin)
Adjustable fuel pressure regulator (AEM, Aeromotive)
-6 fuel lines (any brand)
-6 fittings (any brand)
Fuel pressure gauge (any brand)
hmm interesting.
Old 05-15-2009, 10:53 AM   #17
LtNoogie
LtNoogie's Avatar
I have a S/C'd Yaris running tC injectors. The injectors are too big and the car throws a rich mixture CEL every time I start the car. I am thinking of getting a boost-compensated adjustable fuel regulator that I can turn down the psi until my data logger shows that the ECU is no longer struggling to trim back the fuel.
I expect that at my 6psi full boost pressure that my fuel pressure will go up 6psi and keep me at a nice AFR.
