Old 01-13-2020, 01:15 AM   #1
zoidberg444
zoidberg444's Avatar
If you plugged another sensor in and it still threw a circuit code it indicates the problem isn't with the sensor but with the wiring or internal to the airbag module. I can't say I've ever messed with an airbag system before. I would guess it's only safe to check the wires for continuity with the battery disconnected because of the risk of you sending a signal which triggers the airbag. I would wonder if the wires have rubbed through somewhere between the sensor and the cable grommet through the bulkhead. It might not be necessary to replace the harness. If you can find where the break is you could repair it with one of those solder shrink connectors.
UK to Nordkapp in a Yaris
Old 01-17-2020, 04:08 PM   #2
remcafee
Ok so I have been digging in a little deeper, I have done a thorough inspection of the sea under the seats, I unplugged ever single connector, sprayed them with electrical contact cleaner and plugged them all back in, only time will tell if that helps solve the problem, we shall see and I’ll let you all know.
Passenger airbag light on making turn signals and cabin fan not blowing? thatbryanguy General Yaris / Vitz Discussion 17 08-16-2024 10:23 AM
Help me 3rd gen 2015 model b1806 code srs airbag light Hassannazir314 Third Gen Yaris General Discussion 7 09-22-2017 04:55 PM
2008 Yaris No airbag light at all rudycoop DIY / Maintenance / Service 6 09-15-2017 10:22 PM
2009 Yaris airbag light staying on #30 DIY / Maintenance / Service 7 08-27-2015 05:57 AM
Airbag light is on Taiyaki DIY / Maintenance / Service 4 05-26-2009 08:47 PM
