Old 09-11-2017, 01:24 PM   #1
rudycoop
Drives: 2008 Yaris
2008 Yaris No airbag light at all
I bought this Yaris for my girlfriend to commute back and fourth to school. We recently had the airbags replaced on the recall and they noted that the light didn't come on at all when you start the car. I replaced the Airbag ECU and still no light when I turn the car on.
I jumped the pins to get a code and the check engine light blinks NOT the airbag light. I do believe the car has been in an accident with the previous owner.
Thoughts? I am at a loss with this one. The car has the recall replaced airbags and a known good airbag controller installed, but I still get nothing. no light at all ever. The passenger airbag light functions properly however.
What do I do next? Any help would be greatly appreciated.
*NOTE* I considered that the PO maybe was some slimy sort of tech and disabled the bulb all together? I pulled the cluster apart and everything looks normal in there. The bulb is built into the board and doesn't look messed with.
rudycoop is offline   Reply With Quote
Old 09-11-2017, 01:26 PM   #2
Bulb? *shrug*
Old 09-12-2017, 03:50 PM   #3
miiser
miiser's Avatar
Drives: yaris 2009
Bulb? *shrug*
He probably means the red icon that pops up on the dash when you put the ignition to ON. together all the warnings lights pop up to let you know that all notifications work properly. (Photo for reference)
miiser is offline   Reply With Quote
Old 09-12-2017, 04:05 PM   #4
I know what he means.
Old 09-13-2017, 04:25 AM   #5
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Try borrowing a cluster and see what happens...
It should do a self check on all signals and go off..
ncp13 is offline   Reply With Quote
Old 09-15-2017, 01:52 AM   #6
draftpunk
Drives: 2006 Toyota Yaris Sedan YRX
The fuse?
Sent from my SM-G920I using Tapatalk
draftpunk is offline   Reply With Quote
Old 09-15-2017, 10:22 PM   #7
rudycoop
Drives: 2008 Yaris
Originally Posted by draftpunk View Post
The fuse?
Where is the fuse located? I looked though and didn't see anything airbag related.
2008 Yaris Sedan Airbag Light DTC Code 55 mell0n DIY / Maintenance / Service 3 06-12-2017 09:08 PM
SRS warning light, pass. seatbelt light, pass. airbag light PROBLEMS! tylerwatts53 DIY / Maintenance / Service 1 07-17-2014 08:53 AM
one rear brake light don`t work yaris 2008 abou salou Canada 1 04-03-2012 12:38 PM
