Old 08-25-2015, 11:25 PM   #1
#30
Drives: YR
2009 Yaris airbag light staying on
Hi guys. I have a issue with my 09 Yaris. I bought the car with airbags deployed through a light frontal crash. Ive replaced the airbag kit from a 07 Yaris. I bought a new Module suited to the 09 model. The front sensors are from the 07 model..ive since found out that the sensors from the 05-06 are different to 06-07 and 08-11 models but not sure if they are compatible or not??. The airbag light stays on and when I do the self diagnosis the numbers are 83 and 84?? ��.
I have not seen these numbers mentioned on this forum as i have searched. Can anyone shed some light as to the fix please? I dont want to replace the front sensors if this isnt the issue.
Cheers in advance.
#30 is offline   Reply With Quote
Old 08-26-2015, 12:25 AM   #2
nookandcrannycar
Welcome . ^^^^^ Sounds like a CTScott question. Perhaps he will see this, or you could just send him a private message. Good luck .
Old 08-26-2015, 12:44 AM   #3
#30
Drives: YR
Thanks mate ☺. Will send him a message.
Old 08-26-2015, 06:29 AM   #4
83 and 84 are codes for no comm with the Front Satellite sensor LH and RH sensors.
Old 08-26-2015, 07:42 AM   #5
#30
Drives: YR
You mean the 2 front airbag sensors need the correct year ones?
Just a bit confused with the "satelite" term?
Old 08-26-2015, 06:24 PM   #6
That's what the service manual listed, but it did not show the location. After a bit more research the "Satellite" sensors are the side impact sensors.
Old 08-27-2015, 12:43 AM   #7
#30
Drives: YR
Can the original sensors that activated the original airbags be used again? There is no damage to them or can the sensors be tested ?
Old 08-27-2015, 05:57 AM   #8
Yes - As long as the airbags and sensors have not been damaged they are reusable. Make sure that the Airbag ECU that you purchased is really the exact same part number as your original one.
Yaris AIR BAG Passenger light - explanation needed Abk911 DIY / Maintenance / Service 10 04-17-2013 12:36 PM
2008 yaris sedan airbag... Din get answer anywhere yet... Abk911 In Car Entertainment + Electronics (audio / video / alarm) 3 04-08-2013 11:33 PM
