![]() ![]() Drives: 2009 Yaris LE 5 dr Join Date: Feb 2009
well it looks like I did some house cleaning and got rid of the steering rack bolt pics but here are the LCA bolts... the passenger side shaft has eroded (rusted away) more that the other but I'm glad I'm changing them..
If some needs to see the steering rack bolts I can take another pic ... I saved the bolts to show friends the crap Toyota put in these cars.. |
#2 | |
3 Yaris and counting..
that is correct... the sub frame doesn't need to come out..
I needed to removed the drivers side inner tie rod and boot and then wiggle the rack out the passenger side.. it takes a bit of twist and turn and about 5 minutes but out she came... on reinstall it goes in the same way... the inner tie rod is installed after the rack is back on.. |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Cruise control install 2009 Yaris 3 door | PeteZNY | DIY / Maintenance / Service | 125 | 03-31-2024 09:22 AM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
