Old 06-10-2020, 02:31 PM   #1
Zedicus
Drives: scion xb
a lot of times you can just get different length bolts and still use the OEM springs and washes, due to the flange thickness on aftermarket exhausts.
other things i have done include:
using springs from a motorcycle clutch.
cutting the factory sprint in half and using half on each side (severe clearance issues from a knockoff exhaust kit)
cutting the factory flange off and welding it to the new exhaust.
changing out the OEM manifold to a header that used a flat flange or a V-band clamp.
Zedicus is offline   Reply With Quote
Old 06-10-2020, 03:05 PM   #2
remcafee
ok so what if i cut the thread in half on the oem bolt so it clears the primary o2 sensor? but then that would leave the spring all the way compressed and not really do anything right?
Micro Image center exhaust... tooter Performance Modifications 64 10-14-2012 11:07 PM
exhaust help naossoan Performance Modifications 6 09-24-2011 02:06 PM
Spring bolts torque specifications? Taiyaki Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 06-18-2009 05:39 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
