Old 06-10-2020, 02:31 PM   #3
Zedicus
Drives: scion xb
a lot of times you can just get different length bolts and still use the OEM springs and washes, due to the flange thickness on aftermarket exhausts.
other things i have done include:
using springs from a motorcycle clutch.
cutting the factory sprint in half and using half on each side (severe clearance issues from a knockoff exhaust kit)
cutting the factory flange off and welding it to the new exhaust.
changing out the OEM manifold to a header that used a flat flange or a V-band clamp.
Zedicus is offline   Reply With Quote
Micro Image center exhaust... tooter Performance Modifications 64 10-14-2012 11:07 PM
exhaust help naossoan Performance Modifications 6 09-24-2011 02:06 PM
Spring bolts torque specifications? Taiyaki Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 06-18-2009 05:39 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
