Way back when, my mechanic had to pull the axle to rotate the engine forward to remove my exhaust manifold. The seal was slightly damaged when the axle went back in. I had a continuous drip and a bit faster, of course, when the atf was hot. I don't think it's an uncommon occurrence to nick them or slightly damage them on install. I picked up an OE one and he installed it and I had no more leaks.
#2 | |
#3 | |
I personally don't put a lot of stock in the power of prayer, but it seems to have worked wonders for us in a few circumstances. Other than that, good luck, man!
#4 | |
| 06 axle removal issues | TypeReaL | DIY / Maintenance / Service | 3 | 12-24-2019 09:23 AM |
| TRD Delrin Rear Axle Bushing Collars | tmontague | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 12-15-2019 07:50 PM |
| Axle Seal? | naossoan | DIY / Maintenance / Service | 18 | 07-18-2013 06:28 PM |
| Axle seal question | tforkner | DIY / Maintenance / Service | 1 | 01-28-2013 02:02 AM |
| blown axle seal ! | alfmoonspace | DIY / Maintenance / Service | 22 | 09-19-2010 08:58 PM |
