Old 10-13-2020, 11:24 AM   #1
Pinchlite
Drives: 2007 yaris HB
Contacted
I contacted.
Waiting back for more info for 2007 HB
If price is reasonable then I may get.
Its easily DIY.
The Kit looks to be really well made.
Its also mentioned in the comments other calipers and pads can be used.Those are not specific for this setup.
Pinchlite is offline   Reply With Quote
Old 10-13-2020, 11:52 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by Pinchlite View Post
I contacted.
Its easily DIY.
Awesome. Can't wait to hear about it. Wonder if it would make sense to order an extra set of discs and ebrake drum pads.
Old 10-13-2020, 11:57 AM   #3
Pinchlite
The drum pads dont really concern me as they will only be used when parked.Cant see those wearing down with no movement/friction.
The disc drum does concern me though.
If it does work for 2007 models then its probaly the easiest way to get disc setup plug and play.
No need for modifications like other disc conversions(Runstop)and either having to replace axle(SE) part like mentioned on other threads
Old 10-13-2020, 12:36 PM   #4
3rdSEman
3rdSEman's Avatar
Drives: Black 2012 SE manual
First I know nothing about any of these rear brake conversions... could there be from the plant some sort of front/rear proportioning valve to handle differently the two setups available according to trim ? considering what little duty rears do I would be tempted to retain drums as I feel in our Canadian climate an enclosed system handles better salt exposure and corrosion !
3rdSEman is offline   Reply With Quote
Rear axle swap out for disc brake upgrade + 5 lug conversion Neinris Cosmetic Modifications (Exterior/Interior) 48 08-13-2025 07:25 AM
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
Rear Drum to Disc Brake Conversion Mark-UPI Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-12-2015 11:26 PM
drum brake conversion to disc brake bogartvitz Performance Modifications 8 04-15-2013 10:21 PM
For those who have the rear disc brake conversion mrbond Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 06-05-2009 04:01 PM
