Old 05-19-2021, 12:36 PM   #1
bronsin
bronsin's Avatar
Do you have a volt ohm meter? See if you have 12 V at the switch if not that’s the problem. If you have 12 to switch it’s the switch
Old 05-19-2021, 01:36 PM   #2
tobsie
Drives: Yaris Hybrid 1.5
Oops, forgot to mention. I measured it at the power window connector in de door (to the motor). I meassured 0 volt when pushing or pulling the switch.
To be sure I also measured the passenger power window connector. This gave 12 volt.
But, the passenger only had a 2 wire plug. The driver side window had more wires. There were 2 wires which were thicker and looked the same as the passenger side wire plug. So I meassured those. The other were all thin wires.
Is this correct or am I meassuring wrong?
All the other function on the panel work, so the panel has 12 volt.
tobsie is offline   Reply With Quote
Power door lock and window buttons stopped working crshortt DIY / Maintenance / Service 1 05-15-2024 06:57 PM
Power window wiring diagram Dudejustus General Yaris / Vitz Discussion 2 04-03-2018 01:02 AM
Driver Side Wiper Issue justfillingtime DIY / Maintenance / Service 2 02-15-2013 08:08 AM
