Old 03-04-2022, 05:48 PM   #2
There is no way to deactivate code in order to fake out inspection.
Yes, the sensor is incorporated into the hub/bearing. You can attempt to clean possible corrosion on the wiring harness to hub connector. Some people have had success doing this with results that range from short term to long term. If successful, it should last long enough to get through safety.
The ABS fault has typically been attributed to the connector, not the hub/bearing.
https://www.yarisworld.com/forums/sh...ad.php?t=61655
ABS light on randomly toyotavios_11 DIY / Maintenance / Service 2 07-21-2025 07:00 AM
Grinding noise at low speed Trac ABS light blinking ojeysky DIY / Maintenance / Service 1 09-04-2019 11:44 AM
parking brake light on & abs light on ! car stuck in 2nd gear !!! Bony_ahmed DIY / Maintenance / Service 3 04-29-2019 06:57 AM
ABS light on (without parking brake light) WildChild DIY / Maintenance / Service 15 05-06-2018 12:40 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
