Old 02-09-2023, 09:11 PM   #1
sh0rtlife
5mm when your on 14s is ALOT lol when your talking about bigger calipers
i just made note than an 03 prius..uses 255mm rear rotors...prius rotors and calipers should clear, at that point its mounting them..and any weirdness with the hand brake cables
how are you handling the brake cables anyway
Old 02-10-2023, 08:30 AM   #2
Neinris
I'm using the 2012 Yaris SE parking cables, they'll work with the Corolla calipers, that's one of the first thing I looked at before I envisioned the swap. With the exception of the hangers that they come with, they're pretty much a drop in. I'd have to route it differently than the Yaris though, because the mechanism for the Corolla pulls from the top. And the Corolla's calipers has to be clocked around 2 (driver side) and 10 (passenger side) O'clock to point the bleeder valve up. The Yaris' calipers are fine to be at 3 and 9 O'clock since the bleeder valve will already be pointing slightly upwards. See pics below, the shinny caliper is for the Yaris.
Old 02-10-2023, 03:10 PM   #3
Neinris
I just realized I could run just one long rubber hose per side to the rear calipers instead of having multiple couplings. I’ll buy the Corolla rear brake lines and see if they’re long enough.
File Type: jpeg D0B1750D-439F-4CBB-88AD-013458E820E4.jpeg (244.9 KB, 48 views)
Old 02-10-2023, 04:19 PM   #4
Compeer
Drives: NCP90 TRD Yaris Manual
Just go to a brake shop and have hardlines made at that point and move the tabs at the same time, you would need to make propper mounts to hold the hose correctly may as well just get little hardlines made and move it, but personally I just went back to stock holes. Need to put my tein flex z back on soon, I want some 5mm spacers.
Compeer is offline   Reply With Quote
Old 02-10-2023, 07:55 PM   #5
Neinris
I actually have all the hardware I need to do the disc brake swap, minus the brackets for the hose lines. I wanted a different approach to reduce the coupling from hardline to rubber, to hard line again, then rubber to the caliper.
File Type: jpeg 1F26627A-C30C-4EE0-9005-95CC2A61EB62.jpeg (311.7 KB, 75 views)
Old 02-11-2023, 06:17 PM   #6
Compeer
Hell yeah you have been shopping, this is going to be a sweet setup!
Old 02-11-2023, 08:24 PM   #7
Neinris
Yeah little by little… I had to do my research first before I pulled the trigger. ��
You guys taught me something, to not use a long one piece hose, unless it’s braided. But I think I’ll just stick with what I already have.
The bracket relocation is easy. I think I know what to do now, and hope to install next weekend. I need to use the drill press at work. ��
Runstop Rear Disc Salvageable? ilikerice Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 05-26-2016 04:38 PM
Rear Drum to Disc Brake Conversion Mark-UPI Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-12-2015 11:26 PM
Questions About rear disc brake system???? jyfro_13 DIY / Maintenance / Service 4 12-22-2009 09:25 PM
