Old 02-17-2023, 12:31 PM   #13
sh0rtlife
Originally Posted by Compeer View Post
The clips atleast need to be the original hardened spring steel, Alu cannot work as a spring.
exactly true, the aluminum is just going to let it go under pressure, or bend back n forth till it breaks off...it may not be "quick" but eventual inevitability
if you want "new" look for street rod hose mounts, if you want quick n dirty either cut some off a TRUCK/SUV...or even a car..tho on a car its hard to get enough materiel left to mount them
you can even look at clutch hose mounts, it only needs to fit the hose not the car, alot of the street rod ones are either studded for mounting or threaded for mounting so its easier to slap em in and be done
also aluminum on aluminum can and WILL corrode in fairly short order
Runstop Rear Disc Salvageable? ilikerice Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 05-26-2016 04:38 PM
Rear Drum to Disc Brake Conversion Mark-UPI Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-12-2015 11:26 PM
Questions About rear disc brake system???? jyfro_13 DIY / Maintenance / Service 4 12-22-2009 09:25 PM
