Old 02-16-2023, 03:57 PM   #14
Neinris
Brackets made…
I made the brackets out of aluminum angle, I couldn’t find anything else that’s 1/16in thick. Well at least I know they won’t corrode, and they’re strong enough that I can’t fold them by hand. I cheaped out and made my own retaining clips too…
Once I position them on the axle frame, I’ll drill holes on the base and rivet them down. Yeah I know not welded, but it should still work.
I also made two extra ones with smaller hole, incase the hoses I’m relocating are differently designed than this hose. The hose in the pic is one that will connect to the caliper.
I don’t know why the first pic is upside down…
Runstop Rear Disc Salvageable? ilikerice Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 05-26-2016 04:38 PM
Rear Drum to Disc Brake Conversion Mark-UPI Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-12-2015 11:26 PM
Questions About rear disc brake system???? jyfro_13 DIY / Maintenance / Service 4 12-22-2009 09:25 PM
